STROJNISTVO.com • Poglej temo - Širina in višina okenca v Excelu
OdgovorNapisal/-a promehanik » 5.10.2011 12:44
Rad bi nastavil velikost okenca v Excelu 2003 na 100mm x 50mm. Zanima me kako to naredim? Problem je v tem, da ne vem kakšne enote Excel uporablja.
lp, prom
promehanik
Prispevkov: 560
Pridružen: 16.2.2005 23:40
OdgovorNapisal/-a moi » 5.10.2011 13:03
piksle uporablja se mi zdi.
On a worksheet, you can specify a column width of 0 (zero) to 255. This value represents the number of characters that can be displayed in a cell that is formatted with the standard font (standard font: The default text font for worksheets. The standard font determines the default font for the Normal cell style.). If the column width is set to 0, the column is hidden.
You can specify a row height of 0 (zero) to 409. This value represents the height measurement in points (1 point equals approximately 1/72 inch). If the row height is set to 0, the row is hidden.
moi
Prispevkov: 1989
Pridružen: 26.12.2005 17:21
