STROJNISTVO.com • Poglej temo - Imperial Drill Bit Set (1/4" sveder)
OdgovorNapisal/-a Habegger » 10.9.2020 12:27
Hey guys,
I am newbie here, with so poor Slovene that I will rather not try to use it to not offend anyone :wink:
Can you give me a hint, please, where I'd be able to buy set of drills in imperial sizes here (preferably around LJ). In Czech Republic (where I am from) it is relatively common thing, but I struggle to find here, I believe just because I don't know how to search for it.
Specifically now I need 1/4" (6.35mm) drill, I found one offered by Conrad.si, but it is quite pricy and some basic set would be probably more useful for the future.
Hvala, lp, Tomáš
Ni materni govorec, uporabljam prevajalec (fluent in English)
Habegger
Prispevkov: 20
Pridružen: 30.3.2020 14:23
Re: Imperial Drill Bit Set (1/4" sveder)
OdgovorNapisal/-a -M- » 12.9.2020 8:31
BTS Company
Prispevkov: 1333
OdgovorNapisal/-a Habegger » 30.9.2020 11:50
Thanks for the hint, -M-! I missed your answer as I expected email notification, but it was turned off, bumped into it just now.
Meanwhile I ordered just two pieces of the sveder I need now at Štirn in Vrhnika - they provide probably whatever you pick from RUKO catalogue, only waiting times are quite frustrating (two weeks at least).. But I switched to different project, so it is OK.
Cheers, Tomáš
Habegger
Prispevkov: 20
