STROJNISTVO.com • Poglej temo - Urejanje glave v inventorju?
OdgovorNapisal/-a bavcar » 20.1.2006 7:31
Zanima me kako se ureja glavo v inventorju, v .idw?
bavcar
Prispevkov: 161
Pridružen: 7.12.2005 7:07
OdgovorNapisal/-a gregorci » 20.1.2006 11:45
To zahteva kar dost pisanja...
Na kratko pa:
v IDW-ju greš na drevesni meni - sheet-title block
desni kli in Edit definition
Odpre se ti možnost spreminjanja in urejanja glave. Definiraš polja (Property fields ),ki se ti avtomatsko izpolnijo:datum, ime avtorja ipd.Potem pa si še definiraš polja ( Prompted Entry) ki naj bi se vsakokrat znova popravljala oz bi jih ti izpolnjeval podobno kot pri MDT-ju oz te vpraša po vnosu...
Ko si delaš svojo glavo z vsemi vnosi, shrani potem to risbo s to glavo kot predlogo!!! V eni predlogi si lahko definiraš več glav ( sestavniva, delavniška..)
MAlo si še poglej v HELP, kjer na krako piše tudi naslednje...
You can customize title block formats in the standard drawing templates or you can create your own title block formats.
Open an .idw file. On the Format menu, click Define New Title Block. The current sheet becomes an active sketch.
Use tools on the Sketch panel bar to draw the title block.
To insert text, click Text on the Sketch panel bar, and then click in the graphics window to place the insertion point for the text box, or drag to define the area of the text box.
In the Format Text dialog box, select the text type, and set the text formatting. When you use the Property fields, information in the drawing is automatically updated when changes are made to the model.
When the title block is complete, right-click in the sketch window, and select Save Title Block. Enter the name of the new title block.
The new title block is added to the Drawing Resources folder in the drawing browser.
Tips:
To reorder title block formats, drag the title block format to the appropriate position in the Title Blocks list.
To copy a title block format to another drawing, right-click a title block format, and choose Copy from the menu. Open the destination drawing, right-click the Title Blocks entry, and choose Paste.
Use the Drawing Resource Transfer wizard to transfer title blocks and other drawing resources from a source drawing to one or more destination drawings.
gregorci
Prispevkov: 449
Pridružen: 10.4.2003 7:43
OdgovorNapisal/-a bavcar » 20.1.2006 12:21
gregorci napisal/-a:To zahteva kar dost pisanja...
Na kratko pa:
hvala za razlago! bom poskušal:) lp
Tips:
bavcar
Prispevkov: 161
OdgovorNapisal/-a magnum357 » 20.1.2006 16:36
Ja in zakaj je potrebno citat prepisat v svoj prispevek, potem pa nič svojega zraven napisat. A si ostal z odprimi usti in samo buljil v prispevek predhodnika?
magnum357
Prispevkov: 807
Pridružen: 1.8.2005 9:40
