korenje napisal/-a:A kdo ve kako izmerit izbrano dolžino elementov v draftsight?
Trenutno je tako da moram joinat elemente in potem izmerit kar zna biti naporno. Problem je še ker se v draftsight lahko joina samo sorodne elemente (ravne črte, loki, polyline ipd posebej).
korenje napisal/-a:Zanima me kako izmerit dolžino vseh črt, ki niso samo ravne črte.
Deutz napisal/-a:korenje napisal/-a:Zanima me kako izmerit dolžino vseh črt, ki niso samo ravne črte.
...misliš dolžino objekta ki je sestavljen od različnih črt ki niso samo ravne črte, ali pa dolžino vseh črt ki sestavljajo objekt kot mpr. obseg ?
Private Function ReadBlockFile(ByRef dsApp As DraftSight.Application, ByRef dsDoc As DraftSight.Document, ByRef dsModel As DraftSight.Model, ByRef dsSketchManager As DraftSight.SketchManager, ByRef dsViewManager As DraftSight.ViewManager, dsSelectionManager As DraftSight.SelectionManager) As Variant
Dim s_masa, s_material, s_naziv, s_obdelava, s_opomba, s_strisbe, s_kolicina, s_ident, s_debelina, s_dolzina, s_povrsina
Dim objcount As Integer, selectedObjectsType As Variant, selectedObjects As Variant, contour() As Object, contourtypes() As dsObjectType_e, contourdim() As Object, contourdimtypes() As dsObjectType_e, blocks() As Object, blockstypes() As dsObjectType_e, boundx1 As Double, boundy1 As Double, boundx2 As Double, boundy2 As Double, X1 As Double, Y1 As Double, z1 As Double, X2 As Double, Y2 As Double, z2 As Double, bounddimx As Double, bounddimy As Double
ReDim contour(0)
ReDim contourtypes(0)
ReDim contourdim(0)
ReDim contourdimtypes(0)
ReDim blocks(0)
ReDim blockstypes(0)
' line length
Call dsSketchManager.GetEntities(dsSelectionManager.GetSelectionFilter, Null, selectedObjectsType, selectedObjects)
If IsEmpty(selectedObjects) = False Then
Dim length As Double
For i = 0 To UBound(selectedObjects)
Select Case selectedObjectsType(i)
Case dsCircleArcType, dsCircleType, dsLineType, dsMathCircArcType, dsMathEllipArcType, dsMathLineType, dsPolyLineType, dsSplineType
length = length + selectedObjects(i).GetLength
Set contour(UBound(contour)) = selectedObjects(i)
ReDim Preserve contour(UBound(contour) + 1)
contourtypes(UBound(contourtypes)) = selectedObjectsType(i)
ReDim Preserve contourtypes(UBound(contourtypes) + 1)
Call selectedObjects(i).GetBoundingBox(X1, Y1, z1, X2, Y2, z2)
If objcount = 0 Then
boundx1 = X1
boundy1 = Y1
boundx2 = X2
boundy2 = Y2
Else
If X1 < boundx1 Then boundx1 = X1
If Y1 < boundy1 Then boundy1 = Y1
If X2 > boundx2 Then boundx2 = X2
If Y2 > boundy2 Then boundy2 = Y2
End If
objcount = objcount + 1
Case dsAlignedDimensionType, dsAngularDimensionType, dsAngularDimensionType_2Line, dsAngularDimensionType_3Point, dsArcLengthDimensionType, dsDiameterthDimensionType, dsGeneralDimensionType, dsJoggedDimensionType, dsOrdinateDimensionType, dsRadialDimensionType, dsRotatedDimensionType
Set contourdim(UBound(contourdim)) = selectedObjects(i)
ReDim Preserve contourdim(UBound(contourdim) + 1)
contourdimtypes(UBound(contourdimtypes)) = selectedObjectsType(i)
ReDim Preserve contourdimtypes(UBound(contourdimtypes) + 1)
Case dsBlockInstanceType
Set blocks(UBound(blocks)) = selectedObjects(i)
ReDim Preserve blocks(UBound(blocks) + 1)
blockstypes(UBound(blockstypes)) = selectedObjectsType(i)
ReDim Preserve blockstypes(UBound(blockstypes) + 1)
End Select
Next
If UBound(contour) > -1 Then ReDim Preserve contour(UBound(contour) - 1)
If UBound(contourtypes) > -1 Then ReDim Preserve contourtypes(UBound(contourtypes) - 1)
If UBound(contourdim) > -1 Then ReDim Preserve contourdim(UBound(contourdim) - 1)
If UBound(contourdimtypes) > -1 Then ReDim Preserve contourdimtypes(UBound(contourdimtypes) - 1)
If UBound(blocks) > -1 Then ReDim Preserve blocks(UBound(blocks) - 1)
If UBound(blockstypes) > -1 Then ReDim Preserve blockstypes(UBound(blockstypes) - 1)
End If
bounddimx = Abs(Abs(boundx1) + boundx2)
bounddimy = Abs(Abs(boundy1) + boundy2)
' dsApp.GetCommandMessage.PrintLine "Total length: " & Round(Length, 2) & " mm" & vbNewLine _
' & "Grouped entities: " & RGroupBlock.GetEntitiesCount & vbNewLine _
' & "Bounding box: X1:" & boundx1 & " Y1:" & boundy1 & " X2:" & boundx2 & " Y2:" & boundy2 & vbNewLine _
' & "Bound dimension: " & Round(bounddimx, 2) & "x" & Round(bounddimy, 2)
' used variables:
' contour [object]: contour
' Length [double]: Length
' Bounds [double]: boundx1, boundy1, boundx2, boundy2
' Bound dim. [double]: bounddimx, bounddimy
' blocks
Dim blockinst As BlockInstance, battrdef() As Object, attrdef As DraftSight.AttributeDefinition, battrinst() As Object, attrinst As DraftSight.AttributeInstance
dsSelectionManager.GetSelectionFilter.AddEntityType dsBlockInstanceType
Set blockinst = selectedObjects(i)
'dsApp.GetCommandMessage.PrintLine "Block Handle: " & blockinst.GetBlockDefinition.Handle & vbNewLine _
'& "Block Name: " & blockinst.GetBlockDefinition.GetName
If blockinst.GetBlockDefinition.GetName = "DWG_TITLEBLOCK" Then
battrdef = blockinst.GetBlockDefinition.GetAttributeDefinitions
battrinst = blockinst.GetAttributeInstances
Exit For
End If
End Select
Next
'dsApp.GetCommandMessage.PrintLine "Counted blocks: " & ObjCount
End If
If Not UBound(battrdef) < 0 Then
For i = 0 To UBound(battrdef)
Set attrdef = battrdef(i)
Set attrinst = battrinst(i)
Select Case attrdef.Name
Case "DEBELINA"
If LenB(s_debelina) > 0 Then
attrinst.Value = s_debelina
Else
s_debelina = attrinst.Value
End If
Case "DOLZINA_REZA"
If LenB(s_dolzina) > 0 Then
attrinst.Value = s_dolzina
Else
attrinst.Value = Round(length, 2)
s_dolzina = attrinst.Value
End If
Case "IDENT"
If LenB(s_ident) > 0 Then
attrinst.Value = s_ident
Else
s_ident = attrinst.Value
End If
Case "KOLICINA"
If LenB(s_kolicina) > 0 Then
attrinst.Value = s_kolicina
Else
If IsNumeric(attrinst.Value) = False Then
attrinst.Value = 0
End If
s_kolicina = attrinst.Value
End If
Case "MATERIAL"
If LenB(s_material) > 0 Then
attrinst.Value = s_material
Else
s_material = attrinst.Value
End If
Case "NAZIV"
If LenB(s_naziv) > 0 Then
attrinst.Value = s_naziv
Else
s_naziv = attrinst.Value
End If
Case "OBDELAVA"
If LenB(s_obdelava) > 0 Then
attrinst.Value = s_obdelava
Else
s_obdelava = attrinst.Value
End If
Case "OPOMBA"
If LenB(s_opomba) > 0 Then
attrinst.Value = s_opomba
Else
s_opomba = attrinst.Value
End If
Case "POVRSINA"
If LenB(s_povrsina) > 0 Then
attrinst.Value = s_povrsina
Else
attrinst.Value = Round(bounddimx, 1) & "x" & Round(bounddimy, 1)
s_povrsina = attrinst.Value
End If
Case "ST_RISBE"
If LenB(s_strisbe) > 0 Then
attrinst.Value = s_strisbe
Else
s_strisbe = attrinst.Value
End If
End Select
Next
Case "MASA"
If LenB(s_masa) > 0 Then
attrinst.Value = s_masa
Else
attrinst.Value = Round(calc_masa(bounddimx, bounddimy, IIf(IsNumeric(s_debelina) = True, s_debelina, 0), 8), 1)
s_masa = attrinst.Value
End If
End Select
Next
End If
' used variables:
' BlockInstance: blockinst
' Block attributes: s_masa, s_material, s_naziv, s_obdelava, s_opomba, s_strisbe, s_kolicina, s_ident, s_debelina, s_dolzina, s_povrsina
ReadBlockFile = Array(Array(contourtypes, contour, contourdimtypes, contourdim, blockstypes, blocks), Array(length, bounddimx, bounddimy, boundx1, boundy1), Array(s_masa, s_material, s_naziv, s_obdelava, s_opomba, s_strisbe, s_kolicina, s_ident, s_debelina, s_dolzina, s_povrsina))
End Function
Function calc_masa(ByVal X As Double, ByVal Y As Double, ByVal s As Double, ByVal density As Double)
calc_masa = (X * Y * s) / 1000000 * density
End Function
