STROJNISTVO.com • Poglej temo - Marking Calliper - where to buy?
OdgovorNapisal/-a Habegger » 11.2.2021 11:08
Hey guys,
how do you call this tool in Slovene? Could you recommend Slovene shop, where to buy one (good quality)?
Hvala, T.
Ni materni govorec, uporabljam prevajalec (fluent in English)
Habegger
Prispevkov: 20
Pridružen: 30.3.2020 14:23
Re: Marking Calliper - where to buy?
OdgovorNapisal/-a Demz » 11.2.2021 11:37
Štrajhmass. :) Ali "vzporedni črtalnik".
Pa - če mene vprašaš, ta ni tapravi. Taprav je - hmmm, moram najti sliko.
OdgovorNapisal/-a Demz » 11.2.2021 11:48
Evo
M5057002 Streichmass mit runder Stange und runder Platte 200mm Streich.jpg.res-1400x800.jpg
M5057002 Streichmass mit runder Stange und runder Platte 200mm Streich.jpg.res-1400x800.jpg (37.44 KiB) Videno 5390 krat
OdgovorNapisal/-a Habegger » 11.2.2021 12:04
Hvala, Demz! Imaš kakšno idejo, kje kupiti ta orodja?
EDIT: I've found this now: https://www.almo.si/izrisovalna-tehnika (they call it "Zarisovalno pomično merilo").
Habegger
Prispevkov: 20
OdgovorNapisal/-a Demz » 11.2.2021 14:06
BTS v Lj. Imajo na zalogi.
OdgovorNapisal/-a Habegger » 11.2.2021 14:29
Cool, will ask there also, hvala again, T.
Habegger
Prispevkov: 20
OdgovorNapisal/-a borisk » 12.2.2021 11:31
to dobiš v vsaki malo bolj založeni trgovini z merilnim orodjem.
https://www.wd-tehnik.si/oprema/merilna ... om-izdelek
dobiš pa tudi pri bts, fridro, hoffmannu, itd....
OdgovorNapisal/-a Habegger » 12.2.2021 11:42
Yup, key was the Slovene name for the product, now it's much easier to search for it and I have found few places myself. Hvala, lp, T.
Habegger
Prispevkov: 20
