STROJNISTVO.com • Poglej temo - XPK file
XPK file
XPK file
OdgovorNapisal/-a franca » 27.2.2004 7:43
Lep pozdrav
Dobili smo xpk file narejen verjetno v parasolidu, pa ga ne moremo odpreti. Uporabljamo proe (win NT).
Je mogoče kakšna rešitev ?
Hvala za pomoč
Lp Franca
franca
OdgovorNapisal/-a Gost » 27.2.2004 8:03
Tole sem našel na internetu:
About XPK
XPK is an interfacing standard between application programs and packer libraries. Every XPK application program can pack data with any XPK packer.
The XPK system consists of a master library (libxpkmaster.so) and several (un)packer sublibraries (libxpkXXXX.so). Application programs only use the master library directly: the master library takes care of loading and using the sublibraries. Each sublibrary implements one type of compression. There are different libraries for different types of data. When unpacking the applications do not need to know which library was used to pack the data - the appropriate library needs to be installed.
This port is not complete and is under development. Only a few sublibraries are currently available and not all of them work perfectly.
LP :)
Gost
OdgovorNapisal/-a Mazo » 27.2.2004 18:58
*.xpk je format namenjen izmenjavi datotek med Ideasom in UG do trenutka ko si še ne delita istega matematičnga jedra. Mi upoabljamo UG NX2 in mi lahko pošlješ file pa ti ga pretvorim v *.iges ali*.step.
Mazo
Mazo
OdgovorNapisal/-a franca » 27.2.2004 19:49
Najlepša hvala za pomoč.
Sem že zjutraj klical, če mi lahko pošljejo step, pa so obljubili za ponedeljek. Bom videl ko pridem na "šiht".
Hvala g. Mazo
Lp Franca
franca
