INSTALLING
The installation manager quits immediately after the language selection
by itself and gives no error message from this.
Also in the installation log files is the reason not clear.
Background:
The environment variable "PATH" is longer than 255 characters. Thus
work e.g. so simple commands like "ping" or "tracert"
no longer in a DOS box.
Since the installation also wants to write this variable,
This is probably no longer possible.
Workaround
In the environment variables, the variable "Path" and tidy
remove unnecessary items.
Then TruTops can be installed.
There must be at least the entries
C: \ Windows \ or C: \ Windows \ System32 \ in the PATH variable exists
and his work.
TW541gh programmatically is clear from Umgebungsbariablen
very problematic, because under the circumstances existing installations
then no longer run.
For more detailed analysis protocols are the system and all information
required.
antua napisal/-a:Imam original program z licenco, medtem ko sem update na XP SP3 speljal brez problemov, se mi na Visti(SLO-biznis)instalacija ne izvede, po izbiri jezika se zadeva ustavi brez errorja. System support mi je poslal nekaj v nemskem jeziku in klele je problem.
Sem only english pa software freak tud nisem. A kdo konkretno ve kaj je treba narediti ????????
our development department has checked your software performance report.
We would now like to inform you about the result.
We are sorry to inform you that we will not be able to put your
desired changes into practice.
Description
INSTALLATION
Der InstallationsManager beendet sich sofort nach der Sprachauswahl
von selbst und gibt keine Fehlermeldung dazu aus.
Auch in den Installations-Logfiles ist der Grund nicht ersichtlich.
Hintergrund:
Die Umgebungsvariable "PATH" ist länger als 255 Zeichen. Somit
funktionieren z.B. so einfache Befehle wie "ping" oder "tracert"
nicht mehr in der DOS-Box.
Da die Installation ebenfalls in diese Variable schreiben möchte,
ist dies wohl nicht mehr möglich.
Workaround
In den Umgebungsvariablen die Variable "Path" aufräumen und
unnötige Einträge entfernen.
Danach kann TruTops installiert werden.
Es müssen mindestens die Einträge
C:\Windows\ und C:\Windows\System32\ in der PATH-Variable vorhanden
sein und funktionieren.
TW541gh: Programmatisches aufräumen von Umgebungsbariablen ist
sehr problematisch, da unter Umständen bestehende Installationen
anschließend nicht mehr lauffähig sind.
Zur genaueren Analyse sind die Protokolle und alle Systeminformationen
erforderlich.
With best regards
