STROJNISTVO.com • Poglej temo - CNC grafični program
OdgovorNapisal/-a Gost » 5.6.2004 12:12
a gdo pozna kakšno stran kjer bi lahka downloadu program za cnc s katerim bi lahka z program naredu kos.obistvu grafično narisu kos in potem program sam naredu program,na podlagi slike, en od teh programov je tudi turn plus ki ga uporblja proizvejalec gildemaister ki dela cnc stružnice .a obstaja kakšna stran kjer bi lahka downloaudu tak program . hvala
Gost
AdvaNum Programming Center Professional Edition 3.0
OdgovorNapisal/-a Strojničar » 24.6.2004 23:22
Verjetno misliš ta program:
License: Shareware
Price: $399.00
Expires after Unlimited
Information:
This program allows you to create NC programs from two-dimensional drawings. It combines simplified CAD and CAM features, an editor for two-dimensional drawings, and a CNC program editor.
You can create new drawings, import existing drawings in DXF format, build fillets, chamfers and splines, perform various drawing transformations, and convert your drawings into programs. The output NC language can be customized using XML-based language definition files.
You can create contours, create pockets with islands and use more than 80 built-in macro programs. The Cutting and Language wizards optimize cutting conditions and edit your NC programs.
Strojničar
Po forumu brska: Bing [Bot] in 8 gostov
