STROJNISTVO.com • Poglej temo - Vizualna kontrola zvarov
OdgovorNapisal/-a jan.23 » 13.12.2009 10:42
Baklava, predvsem me zanima kako zgleda poročilo o vizualani kontroli zvarov. Poročilo o RTG in penetrantih imam.
OdgovorNapisal/-a baklava » 13.12.2009 11:26
jan.23 napisal/-a:Baklava, predvsem me zanima kako zgleda poročilo o vizualani kontroli zvarov. Poročilo o RTG in penetrantih imam.
EN 970:
10 Examination records
It is not always necessary to keep a record of the examination. However, when specified, a record should be kept to show that every relevant item of visual examination at each stage has been checked. The following lists the information that should be included in the report:
a) name of the component manufacturer;
b) name of the examining body, if different from a);
c) identification of the object examined;
d) material;
e) type of joint;
f) material thickness;
g) welding process;
h) acceptance criteria;
i) imperfections exceeding the acceptance criteria
and their location;
j) the extent of examination with reference to
drawings as appropriate;
k) examination devices used;
l) result of examination with reference to acceptance
criteria;
m) name of examiner and date of examination.
Where required, welds that have been examined and approved should be suitably marked or identified. When it is required to have a permanent visual record of a weld as examined, photographs or accurate sketches or both should be made with any imperfections clearly indicated.
baklava
Prispevkov: 306
Pridružen: 17.2.2005 8:13
OdgovorNapisal/-a jan.23 » 13.12.2009 11:50
Baklava, hvala ti.
OdgovorNapisal/-a mob » 2.5.2010 22:41
Lep pozdrav vsem forumašem!
Rad bi preveril izgled svojih zvarov v prerezu. Zato me zanima, če je možno in kako bi doma v lastni režiji izvedel makro obruse zvarov. Nekaj sem že iskal po spletu a nisem našel nekih praktičnih navodil. Predvsem me zanima glede brušenja in poliranja. Kakšni brusilni mediji se uporabljajo.
Vesel bi bil odgovora nekoga, ki ima s tem iskušnje.
Lep pozdrav!
mob
Prispevkov: 7
Pridružen: 2.5.2010 22:27
OdgovorNapisal/-a zakl » 3.5.2010 6:57
Preverite standarde:
SIST EN ISO 15614-1:2004 - Preskus postopka varjenja
EN ISO 6520-1 - Klasifikacija napak
EN 25817 - Kriterij sprejemljivosti
glede obrusov. Jaz sem zvare razrezal v željenih ravninah, ter jih dal brusit na ploskovno brusilko, z najbolj fino brusno ploščo. jedkali pa so mi jih v TKC-ju. Nastala je zelo lepa slika zvara v prerezu. (mislim, da so včasih uporabljali mravljično kislino, ne me pa za besedo držat;)
zakl
Prispevkov: 662
Pridružen: 23.2.2005 20:56
OdgovorNapisal/-a mob » 3.5.2010 10:08
Hvala za tale odgovor. Bom pogledal za temi standardi. Kolikor sem našel v literaturi se naj bi jedkalo z mešanico dušikove kisline in alkohola. Še vedno pa me zanima kakšen je postopek končne mehanske obdelave- poliranje pred jedkanjem.
mob
Prispevkov: 7
OdgovorNapisal/-a zakl » 3.5.2010 12:24
mob napisal/-a:Hvala za tale odgovor. Bom pogledal za temi standardi. Kolikor sem našel v literaturi se naj bi jedkalo z mešanico dušikove kisline in alkohola. Še vedno pa me zanima kakšen je postopek končne mehanske obdelave- poliranje pred jedkanjem.
jaz nisem nič poliral, pa so bili zelo zadovoljivi rezultati.
daj mi tvoj kontakt na zs.
zakl
Prispevkov: 662
