Tukaj so zdaj točne lastnosti te plasme, vendar upam da vas ne moti ker so v angleščini, zgleda pa kot na sliki ter ima dva motorčka ki jo usmerjata eden je viden na tej sliki, ki jo prilagam, prosim za kak nasvet, kako jo spremeniti v cnc rezalnik in kakšen bi bil približno strošek, ter katere stvari bi bilo potrebno dokupit da bi stvar delovala.
Hvala za odgovore.
HL-90 Optical Tracer Specifications:
Power:110/115/230 VAC +10%/-15%, 50/60 Hz, single phase with ground connection.
Tracing Accuracy: +/-0.25 mm deviation from a straight pattern edge.
Machine Speed: 1, 2 or 3 metres/min may be selected.
Tracing Speed: square corners to 1 m/min, 1 mm radius corners up to 1.5 m/min, 3 mm radius corners up to 3 m/min.
Kerf Offset: adjustable for cuts up to 3.0 mm wide.
Lead: 3 mm standard, others available for special applications.
Patterns: Silhouette or Line type (minimum line width is 0.6 mm).
Environment: operating temperature 0°C to +50°C, storage temperature -18°C to +65°C, humidity to 95% (non condensing).
From Westinghouse to Wescan Systems, the Linatrol HL-90 has stood the test of time !
HL-90 Features
Universal compact design to suit all small machines.
All operation controls on one panel.
Standard system supports speeds up to 1 metre/minute.
High Power versions to support speeds up to 3 metres/minute.
Dual speed range on High Power systems.
Enhanced cornering circuitry for improved low speed tracing on High Power systems.
Command Mark slowdown option for improved cornering.
Kerf adjustment to 3 mm.
CNC compatible - optional interface connection.
Drives available with optional encoders for CNC operation.
From Westinghouse to Wescan Systems, the Linatrol HL-90 Optical Tracing System has stood the test of time !
